Problem pointing 1000+ with built in switch. | SatelliteGuys.US
surma884
10
NC
I'm trying to point my 1000+ dish with a built in switch. The problem is that it defaults to sat 110. Meaning the stupid switch is always set to 110. I need it to be 119 so that I can point it properly. If I do check switch it only finds 110. My LNB has 110, 118 and 119. So what to do?...
BTW, my receiver is VIP211k.
Disconnect the coax from the receiver, run check switch to clear out the matrix, save, reconnect the coax, from the screen, select 119, then turn your dish until you get a lock on 119, run check switch, save. Hopefully that will do it for you.
Non HD Quality on a Plasma TV
How to enter sub channel number
