I'm having the same problem pairing my Sony Google TV with Dish vip722k. Have you had any luck getting them paired?
Also make sure you are not connecting the receiver to broadband using multiple methods. For example, if you have the Revue connected via wifi and the receiver connected to the Revue with an ethernet cable (the recommended setup), make sure the receiver is not using a USB wifi adapter or a HomePlug device as well. The pairing will fail if this is the case.
It will work for internet access that way. But, because your router doesn't see the 722 as part of your home network (it becomes part of a sub-net with the GTV), you won't be able to share files across the home network.So if I'm currently using a Homeplug adapter to connect my 722 to the internet, when I install my Revue can I stop using the HomePlug and rely on the Revue's WiFi to provide the internet connection to the 722 via the ethernet cable??
yes. that is the prefered method.
Limited time offer
