Pro Plus Twin to QUad | SatelliteGuys.US
kgaspari
12
Southern Nevada
I want to change my Pro Plus Twin LNBF to a Quad. Mounted it up. Signals are excellent. Receivers recognize the Quad but says there is a problem. I must be missing something. Should be as easy as checking the switch, right?
I defer to the experts!
need more detail.
what receivers? If they are Duo you will need TWO lines to the receiver, the quad is not a plus 'switch' so a seperator cannot be used.
Recording?
On the road in a RV
