Primetime anytime not working. | SatelliteGuys.US
dizmatic
22
3
So tonight only abc is recording on prime time anytime. Anybody else have this problem?
I think primetime anytime is useless in my opinion. I tried it just records a whole bunch of garbage.
I think you should have said 'in my case' instead of 'in my opinion.' If you don't watch network programming PTAT is not something you need. You can turn it off for that very reason. For the vast majority PTAT and its Auto Hop is a godsend....
Well that helps the OP and his problem. Thanks. Oh, and perhaps Distants are bunch of garbage to some.
I would give it a day and see if it corrects itself, maybe reboot?
I'm reviving this thread.
Tonight the HWS showed that PTAT was fired, but yet it didn't record anything on any channel though if you looked at tuners, it indicated it was getting ABC. Irritating because some shows had finales that I've now missed. :(
Watching Sports on RS Net (ROOT), can't access guide
anooying hopper glitch?
