I have a 2 Hopper 4 Joey setup. It works flawlessly. But, one of the Joeys serves a guest room that doesn't really need to have access to the families DVR and recall histories. Is there any way to lock the Joey from seeing all of that stuff?
This was a question I asked long ago and was told that yes, these "Parental Control" type features would be included. I guess they were not!
Specifically, I don't want a guest to be able to delete or schedule recordings.
I guess I will be better off staying with what I have.
I also believe you can use an isolator (or it takes two?) and that would prevent a Joey from seeing one of the Hoppers at all..........
The Parental Control options of locking the receiver can be set up on the Hopper and then copied to any or all of the Joeys and works just like all of our receivers.
Mind you, I don't have a H/J (yet) but can you not set the parental controls at the Joey alone ? If you can't and it has to be done on the Hopper, by "copy", could one block the channels and in turn the DVR events on the Hopper, copy it to the Joey, and then delete the controls at the Hopper after copying ?No, I specifically asked if you would be able to limit what specific Joey's can see/do. Apparently you cannot. I do not want to have to lock down a Hopper, and inconvenience me, because I don't want someone in a guest room changing my recordings.
Sounds like they need another config screen, with a matrix of checkboxes you administer from the Hopper to assign abilities.
Columns could be "Manage Timers" "View DVR Events" "Delete DVR events" "View History" "Watch Live TV" etc.
One row per attached Joey.
Uncheck all the boxes except "Live TV" for your guestroom, uncheck "Delete DVR" for the kids, etc.
Limited time offer
