power supply/h-34 | SatelliteGuys.US
power supply/h-34
Unless this is an owned unit, you should look to Directv for repairs/replacement. Opening the box could be problematic for you down the road. BTW, I don't know where you can get a power supply.
I was about to say, the HR34 is just a power cable, that you can by many places, it is very generic.
If you are using an HR44 that uses an external power supply that DirecTV will send you if your's fails, otherwise you'd be looking at ebay or possibly Solid Signal.
If you are truly looking at the internal HR34 power board, well, used HR34 on ebay would be about the only option, nobody sells those as a replacement part that I've seen.
strange problem with HD
Is there any way to order the Preferred Choice package online?
