Power Supply for a DCAW1RO-01 CCK-W | SatelliteGuys.US
Oyving
65
Amboy IL
Hi,
I need a power supply for the cck-w and I don't know what model number I need. I figured that the SG forum is the place to ask!
I dont have this particular model right now, but if you need a cheap replacement look on the bottom of the unit for dcv output. Prolly 9v but check, then look for milliamp or amperage. Take the unit to radioshack and tell them you need a replacement power cord for it. Theyll size the plug to fit and check the dc v and amps. If the unit doesnt say, then check on solid signal if it says.
Sent from my PG06100 using Tapatalk 2
Genie dvr
Connection between Genie and Genie Mini
