Possibility of bad LNBF's? | SatelliteGuys.US
janzy
SatelliteGuys Guru
126
Well I have no signal on my Bev 6100 system. Everything inside my house was disconnected for a rehab for some time and now it won't work.
My broker told me I'll need a rehit when I get a signal and that's my problem...no signal!
I went to the roof and nothing has been moved, so I tested the LNBF's by running a direct wire from the lnbf's to the receiver and still no signal.
Is it possible I got a surge or a lightning hit or something to damage the lnb's?
Is there any other testing I can do and what type of replacements do I buy?
I have a couple of DirectTv ones laying around, will they work?
Yes the direcTV ones will work. Weather seals sometimes go bad on lnb's but to have 2 go at the same time would be extremely rare.
StarChoice NO HD Channels
BEV Equipment Supplier
