Popping sound on one receiver | SatelliteGuys.US
Johninpa
Bloomsburg, PA
I am getting a popping sound about every 5-15 seconds on my tv. It only does it when using the dish, Wii and DVD work fine. I am using a coaxial connection and switched receivers to see if that cured it, did not fix it. I have tried other cables, the only thing I did not do yet was run a line directly from the LNB to the receiver. Any help would be great.
Is your system properly grounded? Have you checked all of the cables and connections?
Found DirecTV Slimline dish
BestBuy and Costco to stop selling recievers
