Poor signal strength for PBS | SatelliteGuys.US
towler
2
La Paz .Mx
I have been having trouble receiving PBS , Ch 915 on Sat 119. A check of signal strength shows only a 9 for Td #8. All others are in 20s and 30s and come in fine. This is new (for the last week.) Does anyone know what has happened? Towler
Yes, I get error reports , both 11-11-25 and usually 11-12-25, The code in the upper right corner has been 002, 004, and 015a, on different days. This is Dish ( USA ) not Dish Mexico. In checking signal strength. Transducer 8 and 9 are the only ones showing low strenght ( below 10 ) Towler
First, all your signal strengths appear to be low. Second on the Western Arc (119) I have a strength of 70 for the National PBS Channel 915 on TP8.
I would be looking to see if any obstructions have started to impede the signal, or if the dish needs to be aligned.
Intuitive Hopper?
Tailgater 2 Available Aug. 21st
