Pointing dish??? | SatelliteGuys.US
Pointing dish???
  • Thread starter Thread starter owlbox
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
owlbox
223
MA
Signal level/quality?
:( After last nights f/w download the Qual is 87, Power 70, s/n 12.79.
I noticed that because of where the arm was mounted on the wall the installer had to pull it down to get out past the roof overhang and therefore the mounting pipe is not vertical. Because of this, there is an interaction between azimuth changes and elevation and it makes it more difficult to peak.
How are these numbers? Do I need to call Voom to get someone to repeak? During install his meter was at 48+ but by the time everything was bolted down that dropped to 43 on the little box he had outside. :confused:
Sound And Vision May Issue On Voom
Is it just me or are there some real a**holes on other forums?!
