Pointing a lone dish at 129 | SatelliteGuys.US
djmaui
193
Maui
I'm in Hawaii and I have a lone 30" dish that is now on 119, which I would like to now point at 129.
Can anyone tell me approximately how many degrees of elevation to lift it and how many degrees to rotate it to the west?
I don't have a signal meter, so I'm using a 501 and a tiny TV to point the dish. I have to be pretty close before beginning to get a signal.
I can't seem to find 129 pointing info.
Mahalo
Mahalo
The 501 isn't going to work since I don't think it will pick up 8PSK modulations... I'm not totally sure on that though.
The only QPSK is 21 and 32 right now on 129. But I doubt you can get those in HI.
Bross, Thank you. That is just the info I wanted. Great site. Up 9.1 degrees and +9.5 degrees azimuth.
Digiblur, I think you are correct. I may need to pull my 722 outside to do this. the conus signal on Ceil-2 is useless for Hawaii. We'll likely only see tp's 2,4,6 14 for now.
Got any diplexers? Diplex the TV1/TV2 signal from the 722 back into the LNB wire and out near the dish and use the UHF remote and TV without moving the 722. Or just run a long cable out the window instead of worrying about knocking around the 722.
I had already moved it when I got your brilliant suggestion. Got 'er pointed and ran a check switch test. 129 has a red x due to reception problem (due to all channels not available?).
Here are the numbers on the 129 spotbeam transponders:
30" dish 129 west
dpp44
722
cloudy, light drizzle
tp1 0 not locked
tp2 73 129 w
tp3 0 not locked
tp4 57 129 w
tp5 0 not locked
tp6 70 129 w
tp7 0 not locked
tp8 0 not locked
tp9 0 not locked
tp10 0 not locked
tp11 0 not locked
tp12 69 locked, name not acquired
tp13 0 not locked
tp14 72 129 w
tp15 0 not locked
tp16 72 129 w
tp17 0 not locked
tp18 0 not locked
tp19 0 not locked
why do some channels not switch immediately?
Dish Rumor
