Pointing a 1000.4 western arc dish | SatelliteGuys.US
CHRISJ364
3
CHICAGO
I am trying to point a 1000.4 western arc in the chicago area. I was unable to find the angles. I was able to find the angles for 1000.2 are the the same? I was unable to get signal with these. I also have 2 dpp44 switches in attic so I can hookup 6 boxes. Some legacy some new. Should I run a cable to only 1 box for setup? I have a small signal finder that I using to tune. Had no trouble tuning dish 500 before the dpp44 switches in attic.
Need to know what number of receivers you are attempting to install.. the settings for a 1000.2 and 1000.4 WA are the same.
If you are hooking up the DPP44 switches you need to run 3 cables from the dish to the switch.
Connect meter and point the dish slightly to the SW then SLOWLY move dish Back and forth until you hit a signal. Peak the signal then run a switch test. If you get 119, 110 ,129 in that order you are good to go. if you get 110, X, 119 you are too far to the East.
where are the sats located in your switch matrix screen?
you should have 119,110,129 in that order....if 110 is first you are about 10 degrees off...if you have 119,110,xx you may have a obstruction blocking 129.
the 129 sat is pretty low in the sky....
The screen was 110 XX 119. If I moved it farther west I could not get anything but a direct sat I think my box did not give a name but my meter was at its peak. I broke down and called Dish.
Thanks for the info guys.
You appear to be receiving 110 on the center LNB so you are pointed at it instead of 119. Your antenna is pointing too far east. You need to move 9 degrees to the west.
MSG back on?
Dish is coming to give me my HD channels for FREE
