Pocketdish question | SatelliteGuys.US
Pocketdish question
AJF
466
2
I have the 500E and was wondering if it can draw power from USB when connected to the 622 or if it must always have the AC adapter connected ?
I have a 700E and it has a battery that lasts for about 3 hours on a charge. 500E does not?
Yes it does but that's not the question . I have 1 AC adapter that came with the unit which I'd like to leave at work where I often hook up the Pocketdish to a TV to watch shows I've recorded. When I take it home to download more shows, I was hoping it would draw power from the USB connection on my 622 so I wouldn't have to keep taking the AC adapter back and forth .
I don't think it is going to pull any power from the USB - if you leave it plugged in at work, then bring it home and put more shows on it, I don't think you are going to have the battery go dead on you. Have you? I don't know about the 500 but on my 700, we watched 4 Prison Break Eps in a row and then I deleted those and put more on it without plugging it in one time. If you aren't watching at home, you should be good!
Need to "move" to get local HD
622 remote won't run my receiver
