Pocket dish availability? | SatelliteGuys.US
wcd911
2
Does anyone know when the pocketdish is going to be available. I have been waiting for one of these for several months. Thanks
Huh? The PocketDish has been discontinued for a long time. The current Dish/Archos solution is to buy a gen 5 Archos and download the free Dish Network plug-in for your 622/722. Annoyingly enough, other receivers (such as my 625) are not supported at this time.
I have a pocket dish AV700E. The new 605 and 705 can be ordered from Archos.com The both have WIFI built in. And the only receivers that work with them have USB 2.0 are the 625 622 &722. Who cares if the don't support PSP or the iphone these are not made by sony. I think Sony has more of the market share than than need since they forced out HDDVD
You sure about that? I see this on the Archos website:
• Only compatible with the ARCHOS 405, 605 wifi and 705 wifi
• Only compatible with Dish Network STB models 622 and 722
I would be delighted if my 625 could be used this way.
Want a job? (Littleton, CO)
Not getting HD signal
