please someone help me | SatelliteGuys.US
shloime
2
israel
i'm have golden media wizard hd receiver and i'm do upgrade by usb Accidentally i'm put on my usb "ALI360X-upgrade-tool.zip that have abs file" after upgrade The reciever doesn't work it not go into operating system please if u can help tell me what to do ? how i'm can upgrade it again !??
Is that a satellite (FTA) receiver?
If so, then this should be posted in the FTA area of the forum, not in the Home Theater area.
Sent from my iPhone5 using SatelliteGuys
I am moving this thread to the FTA area and deleting duplicate threads.
I don't know for sure but if it has a serial port you might be able to fix it that way. Start upgrade and flip the power switch on and see if it takes it
Did you UN-zip it ??
Think you want to unzip it onto your computers HDD, and run the "tool" there, using a serial cable to the STB to do the upgrade. Otherwise, if supported, copy only the .abs file to the USB and perform the upgrade.
But since it's apparently 'bricked' the only way may be the serial cable route.
A quick search, suggests that brand is popular in the UK and Europe.
Dont think they have penetrated North America.
You might get better advice on another forum.
Sorry.
97W Excel-based channel guide almost ready
RT-Doc is up -123W Cband
