Please Help with Wireless Joey connection | SatelliteGuys.US
bgee
SatelliteGuys Guru
144
24
Albany NY
I'm staying in a guest cottage with a wireless Joey connected to the owner's Dish system. There's also a WiFi network on the property.
My wireless Joey has lost connection. After a restart, it is stuck on the "Connect to WAP" screen and wants someone to push the WPS button. However, I believe this system uses the home WiFi network to connect wireless Joey's to the Hopper with no Dish WAP's. The owner is clueless and totally depends on Dish support.
Is there any documentation on setup to use the home's WiFi network as the backbone to connect wireless Joey's to the Hopper without using a Dish private WAP network?
(I'm a long time 722K user back home and not at all familiar with the newer architecture)
As far as I know the wireless joeys must use a DISH WAP, I still have 2 of them (replaced one with a Joey3 due to connectivity problems) and that is how mine are connected, I was never given another option for connecting them. There are no options for inputting passwords or selecting networks from the Joeys that I have ever seen in any of the menus.
Reactions: bgee and TheKrell
Go find the owner's Hopper and see what is plugged in to the Ethernet ports...the Dish WAP would be connected to it via Ethernet. The Dish WAP looks like this:
Did you say why the Joey lost connection? They fact that you can't see the wap makes me think that is why you lost connection. It was somehow either accidently or purposely powered down?
Sent from my SM-G965U1 using Tapatalk
Reactions: TheKrell
I believe the Joey lost connection due to an internal hardware failure. Suddenly network status showed no router detected. Reportedly the other Joey's in the owner's main house had no interruption. They gave me a spare Joey to try and that powers up into the "Connect to WAP" screen.
Based on the responses, there must be a WAP connected to their Hopper with a WPS button that needs pushing.
Yes, find the WAP and you should be able to get the WJ connected. My WAP is connected to my Hopper3 via ethernet connection, you should be able to trace the ethernet cable from the back of the Hopper to find it.
Reactions: TheKrell and bgee
Wally to Hopper 3 DVR transfer
Using a Echostar Ad-3000IP viaccess with a SMW q-pll Quad Lnb Type R
