Pixelation on local channels | SatelliteGuys.US
blake616
14
2
Indiana
Over the past week I have noticed some pixelation and picture freezing only on my local channels on Dish. The regular satellite channels are OK. I also have an antenna and if I switch to local on that the picture is OK.
Anyone else have this issue?
Register to hide this ad
Locals are fine here. What's your DMA?
Adding a suggestion. Unplug your receiver for 10 seconds, and then plug it back in. If that does not solve your issue, you may need to have your dish re-pointed. Locals are on spot beams, and if the dish pointing is not correct, that could be the issue.
I have been having this issue on locals as well. been going on for more than 4 weeks. DMA 531
Dish support just had me reboot everything as usual, that did not change a thing.
I'm originally from Bristol!
As for the pixeling, I'll take a look into this. Can you PM me your receiver number?
Reactions: charlesrshell
I've been fighting this issue for years. My OTA locals are prone to pixelation because of my location. I'm close enough to the transmitter towers but there are several hills in my way. Some days are worse than others and I can find no rhyme or reason - sunny day, cloudy day, rainy day? I often get better reception after the sun goes down. I've tried several different rooftop antennas with no improvement. I have three different ways to watch OTA locals - one is through the tuner in my ViP211k Dish receiver, then there's the tuner in my TV and I also have a ADTH TV Box that performs the best of all three. It also tunes the new ATSC 3.0 NextGen channels. The Dish receiver freaks out and displays "739 Error" screen while it tries to figure out what to do. The tuner in the TV and the ADTH Box handle the interruptions (pixelation) much better and a lot quicker. Airplanes flying between me and the transmitter, a car going past my house and anything else that might cause a reflected signal to arrive at the antenna will cause a dropout. Other times the dropouts must be weather related. Of the three tuners, the ADTH TV Box handles the dropouts the quickest and returns the picture much faster than the Dish receiver and a little faster than the built-in TV tuner. I've got the Dish receiver and the ADTH TV Box connected with HDMI cables. The TV is a Westinghouse "smart" TV so that every time I turn it on, I have to select the input which makes switching between tuners as easy as pressing a button on the remote.
Hills in the way? Have you considered an aerostat? LONG, STRONG cable to the antenna. Get stations from REALLY far away, if you do it right.
Permitting might be a bitch…
I've got a couple of Aerostars sitting in the driveway but the antenna is pointing the other direction. I'm not familiar with the term "aerostat". I'll try changing my lead-in coax when the weather cools some. It's way too hot in the attic right now.
I have been having this pixilation problem for over a year on ABC. I live near Rapid City South Dakota. Anything I record to the DVR is using the OTA channel for ABC. I have not seen this pixilation using the OTA ABC channel. The other broadcast stations are fine.
Joey 4s Losing Connection to Hopper
Eastern Arc seems to be weaker?
