Pioneer Elite PRO-610HD Service menu | SatelliteGuys.US
Lil4cyl
7
Hi all,
I am experiencing the ZOOM in problem in 1080i on my Pioneer PRO-610HD TV, and was wondering is any other Pioneer owners on the forum can tell me how to get into the service menu, as I have heard I can adjust this.
Thanks in advance!
I have the instructions on getting into the service menu for the Pro-910HD, and I think the 610 is the same. Be very careful with any changes.
* Make sure plasma is in standby and the Pioneer media box is powered on.
* Press DISPLAY on the remote.
* Wait at least 3 seconds.
* Press the following keys on the remote, in order:
LEFT
UP
LEFT
POWER
If successful, the set comes up on the INFORMATION page.
Press MUTING to move through the top level menus, which are:
INFORMATION FUNCTION CHECK
COMMON ADJ
OPTION
INITIALIZE
Lil4cyl said:
Hi all,
Thanks in advance!
I have the Pioneer Elite 710HD, and to get to the service menu on it, you look for a small hole on the front of the TV (behind a door), and press a button inside it with a pin or needle. I looked at the service menu once, but couldn't make heads or tails of it, so I just exited out. No user interface at all.
Thanks for the info.. I was thinking about trying to fix the zoom problem my tv has with Voom. I may just let a tech tweak it
VOOM is AMAZING!!!!
installs INK, qualified installers
