Would I be able to tell a difference if I went from a dish 1000.2 pointing at 129,110, and 119 to the eastern arc dish? Does the HD and SD look better with EA? I know it's all mpeg4. Thinking about upgrading.Thanks
Its NO different.
The Mpeg 2 SD resolution is 540x480
The Eastern Arc Mpeg 4 resolution is 480x480.
I've had both and your not missing anything.
Also with the 1000.4 dish, All American Direct DNS locals aren't available.
IMHO You would be Downgrading going too a 1000.4 Eastern arc setup.
Eastern arc is full of Old Satellites.
The 1000.2 is the same dish as 1000.4 , Just the LNB's are spaced differently, But Western arc also has 2 Brand new Very powerfull satellites. Stick to what you have.
Three months ago, FNC was in free preview, and via western arc, it looked like somebody smeared vaseline on my TV. Now that I use eastern arc, and subscribe to FNC, the SD version looks better than when Food upconverts an old episode of Good Eats. G4 is the same story. Screen resolution has little to do with picture quality. Signal strength in KC is only about two thirds as strong as WA was, and rain fade is more common. The improved PQ and simpler wiring were worth it for me, though.
Its not the same Resolution.. Mpeg 4 looks better on hd channels in comparison to the mpeg 2 hd channels we had before. So why wouldn't the mpeg 4 sd channels look better than the mpeg 2 sd channels? Better compression should mean better picture quality without all those compression artifacts and over crowding we had with mpeg 2..
E* Mpeg 2 SD is 540x480 4 channel per TP
E* Mpeg 4 SD is 480x480 7 channel per TP
So sure Mpeg 4 is better, But when you drop the resolution, and cram more channels per Transponder it even out.
I've Had 1000.4 setup for about 6 months, I dropped the 1000.4 for a Dish 500+ so I could have International. I've never noticed any difference in PQ from this change either way.
Limited time offer
