Phoenix area..h20/Hr21? | SatelliteGuys.US
BNDAZ
16
Just ordered an upgrade..in the process i asked if i could have an hr21-700( black).
I was told they had no control over which product i would get , but would notate it on the work order.
Anyone have an thoughts on this...standard?
What is being installed in this area currently?( personal experiences)
I'm in gilbert as well, yes, i just like the aesthetics of the 700.
Is there anything feature wise that makes one better than the other?
I live in Surprise. I January I asked for HR20's to get the ATSC tuners, but they said they had no control. I got HR21's. I think the HR20's are rare to come by. If you do not want to chance it, I know that locally Costco and Best Buy both carry HR21's.
Well, i got the HR21-200 in black.
But i am confused, what does the ATSC tuner do...because i get my locals in HD on this unit.
THAT said, i have my guide set to "channels i get" but is there any way to eliminate the DTV and payperview channels?
ATSC is the OTA digital tuner; sub-channels, most smaller and independent local channels will be available via OTA but not yet via DBS retransmission. If you do not watch those; then its no loss; if you do, then you want ATSC.
You can manage your channels via the FAVORITE CHANNEL LIST setup.
Thanks, i suppose i dont know what i am missing, perhaps when the AM21( i think that is what it is called) add-on unit is available i will add it...
How do i get to the favorite channel list set-up?
Your TV likely already has an ATSC tuner in in and you can use that to determine if you even want/need the add-on devise.
Via the setup menu.
found the set-up..create a custom in favorites by adding all channels i get then eliminating.
Guess what I got in the Mail
2 year committment and package question
