Phase 3 LNB On Larger Dish | SatelliteGuys.US
jeffadelic
7
Durham,N.C.
Is it possible to put a Directv Phase 3 LNB on a 65 or 75 cm elliptical antenna ?
What mounting hardware is needed to attach the the LNB to the antenna ?
I would like to get a better picture for my Directv subscription with less rain fade and drop outs .
Just about anything can be jury rigged but the LNB is designed for the phase 3 dish and will probably perform worse if you can even track the three satellites. You would be far better off with three separate dishes each maxed for improved signal strength. And as Charper1 said the picture quality won't improve with more signal strength just the rain fade will decrease.
Uplink Activity Report - 01/04/2007 - 26 changes
Lifetime sub on HR10-250
