Perfect Vision website? | SatelliteGuys.US
RandallA
10,556
68
San Francisco Bay Area
Does anybody know if Perfect Vision has a website for their products. I've been searching all over and can't find it. I just want to see if they have the specs. for their products. Could it be that they are under the parent company, if any?
Thanks.
The Tate said:
If I remember correctly you can get signed up with them if you are a certified installer.
Not for sure.
That is correct Tate......you have to fill out their app and fax it to them and then they assign u a login and pasword.
Doctor Bob, do you have access to the dealers' section? I'm looking for any specs for their in-line satellite amp PVAMP-1. All I got is the gain 20 db.
Thanks.
The only specs P10 list for the PVAMP1 are as follows:
(from P10 Catelog 20, page 85)
* Freq Range: 950-2150 MHz
* Provides 20 dB Gain
* Powered by Sat Rec 13-18 VDC
This is the same basic information printed on the amp itself.
New Doctor Who Premiere!
New Fios Hd Channels Coming!
