PC to Receiver upgrade for traxis 2500 | SatelliteGuys.US
rjc3895
390
I have the proper RS-232 cable. According to DMSI, I need a standard male to female RS-232 Cable. I also have a null modem cable which can be used if I am doing a reciever to receiver upgrade. Does anyone have any experience upgrading the latest LEGAL software? I've tried following the instruction on DMSI, but I keep getting a connection failed message.
I'm using my old Compaq Presario 1260 laptop with windows 98. I may be a setting on my PC, so I'll keep trying until I can get more information. Any help is greatly apreciated as always.
If anyone with a Traxis 2500 successfully updates the pre-programmed satellite list, let me know. For now I am using the C-Band workaround mentioned in another post by Iceberg.
To recap what was mentioned in that post, if you do not have a C-band dish/lnb, you can select a C-Band satellite from the pre-programmed list of satellites, and manually enter a good KU band frequency, symbol rate, and polarity. Then move the dish east or west to the location of the satellite. You should be able to find a quality signal.
Dish mounting question (roof)
Sat Chart Pdf format
