Sorry, been out awhile. My Coolsat with an 80cm dish is at 66%, and my Pansat with a 1.2m dish is at 73%. Yes, lyngsat is almost the same, on Coolsat - SR is 00004 #'s higher, probably won't make a difference, and on Pansat - SR is 00003 #'s higher, probably won't make a difference. And, both are from previous blind scans, I'm sure.Dr_Brian_Oblivion said:What kind of signal strength ru getting?
ru using the info from lyngsat or just from a blind scan?
Limited time offer
