So, I've been looking at moving my current satellite setup (36" antenna and motor) but I've realized that I do not have any C brackets that you can attach to the mast... The ones that have the "spikes" on the other side to prevent the dish from flopping all over the places.
In any event, I had to use a piece of metal and bend it around the mast and use a series of washers (hahaha) to space it and tighten it down.
Now, I've been combing through the Sadoun site and can't find any of those brackets ( I have, however, found the generic mast 'cause my current setup has bent the old one
http://sadoun.com/Sat/Installation/images/Digipower_SG2100_motor.jpg
They are the two brackets on the right side of the picture.
Maybe I'm an idiot and have looked over them, but does anyone know where I can buy more?
Thanks!
Thanks!
