Parts for StarChoice 60E Dual LNBF | SatelliteGuys.US
BigG
North Carolina
Does anyone know where to get parts for StarChoice elliptical dishes?
I have a broken horn plastic cover on the front of my Dual Satellite Quad output switchable Ku LNBF (Model# LM-2738-SC) used with the StarChoice 60E elliptical dish. (That's the white plastic "dual" cover that points toward the dish). After 3 years outside, the plastic became brittle and just fell apart. Otherwise, the LNBF works fine. Just trying to keep the bugs and rain out....
See attached pictures...
BigG :confused:
NC
The only option would be to either superglue the cover back on yourself, or replace the LNB completely.
The LNB isnt exactly a "servicable" unit, so a replacement cover wouldnt be made available. If that happened in the field, and a SC tech was sent out, they would just replace the whole LNB.
share and view
SC DSR505 Constantly "Artifacting"
