Partial signal loss on original hopper, not on HwS | SatelliteGuys.US
mag314
17
Michigan
I am not super technical, and did not install this system myself. The dish is on a pole in the yard so I can actually reach it if necessary. I have an original Hopper as well as a Hopper with Sling (both used regularly), and a Joey I rarely use. The original Hopper has recently been experiencing a partial or complete loss of signal periodically, and at such times loses internet connection. During these same time periods, the HwS functions just fine, no signal loss at all.
Performing a reset via unplugging the receiver, then checking the switch generally gets the signal back, though I have to also reset the network and I have to reset up the broadband after this, on both machines. I did also change the coax cable on the original Hopper, just in case.
Is there anything else I can do to troubleshoot this? Is my original Hopper giving up the ghost? Or is this something that needs a visit from an installer to check and fix?
Sent from my iPad using SatelliteGuys mobile app
Do you know if you are just losing signal on one satellite or all? What is your signal strength for the different satellites and transponders? Do you get a signal code on the message that shows?
4k Joey or Wireless Joey
Dish 922 ok?
