Parental (Channel) Blocks. | SatelliteGuys.US
NASHMAN1
34
Sandy, Oregon, United States
I would like to know how to take care of the DTV Parental (Channel block) controls? I'm having a hard time trying to find where it is, can somebody please help me?
It may vary by which receiver/dvr you are using. With my HR24 I go to menu, parental and setup, parental controls, edit settings, then to whatever you want to do then.
setup favorites lists
MENU - PARENTAL/FAVS/SETUP - FAVORITES - EDIT SETTINGS
He can't block channels from there, can he? He has to go to menu, parental, parental controls, edit
no, but based on what it sounds like he is really wanting to do, "blocking" doesn't really sound like the correct term; but "hiding" does (his "stealth")
After rereading his second post, I think you are absolutely right!
Screwed By Direct.
DIRECTV Announces New HD!
