Pansat and Dp switches | SatelliteGuys.US
dodge
1,197
Plano, Illinois, United States
I have a pansat 2700a??? Will it work with a DP 34 multiswitch?, have 2 winegard 30" dishes with d style lnb and 2 dp dual lnbs on them.
They are pointed at g10 and T5.. Will ad IAI 5 later. Just wondering how to setup up the ird??? DO you need the diseq turned on and what settinG??
The DP34 is a DiSEqC switch. Ports 1-3 are DiSEqC inputs 1-3.
With the DishPro stacked LNBFs you change polarity by changing the LNB's LO frequency so:
DBS band: 11250 and 14350
FSS band: 10750 and 13850
wont work because the LNB's are for DBS frequencies only (unless they are the FSS LNB's from a Superdish) and G10 & IA5 are Linear
Direcpc LNB
11720V dead on G10R, or did I break something?
