Pansat 6000 *.PVR conversion | SatelliteGuys.US
sparky88
3
Does anyone know what App I need to convert or view Pansat 6000 PVR files?
They have a PVR extension (File.pvr).
They are probably straight transport streams. Most viewers capable of mpeg2 video should work. You might need to change the extension from PVR to MPG though.
Or just right click on the file and select "open with" and select your favorite player and windows will play it with that player. select always use the same program to make it permanent.
Olympics
taking the PCI / DVB card plunge
