Pansat 3500s card reader | SatelliteGuys.US
The card slot on the 3500 is mainly used to update your receiver when new files are made available by Pansat. It can also be used to save channel lists. You need a card reader for your PC too. You simply download the file and transfer it to the card and then put the card into the 3500's slot-very easy. Currently there is not an update that is worth doing that I know of.
Amc 12
New Hobby Need Help Please
