Pansat 2500A Vs. 2300A? | SatelliteGuys.US
Rufus_74
SatelliteGuys Guru
120
What are the main differences between these two receivers? How does the 2300A stack up against its younger "brother." Thanks again for all the help.
Rufus
2700A :
• Full Compliant of MPEG-2 Digital & DVB broadcasting
• 950-2,150 MHz input Frequency (IF Loop Throughout)
• Variable Input Symbol Rate (1-45 Msps)
• Multi Language OSD
• Automatic PAL/NTSC Conversion
• Fast Channel Change
• 5,000 Channels TV & Radio Program
• Flexible reception of SCPC & MCPC from C/Ku-Band Satellites
• S/PDIF (Digital Audio or Dolby AC3 Stream out)
• Timer Function (Automatic Turn On/Off by Setting Function)
• 256 Colors (Graphic User Interface) Number
• PIG (Picture In Graphic)
• 5 Favorite List & Unlimited Programs per each
• Powerful Channel Editing Function*- Sorting : Alphabetic, Satellite, FTA/Scramble, Parental Lock- Move, Delete, Favorite Edit- Parental Lock, Channel Rename, Channel Skip
• Manual PID / Satellite & TP / Network Scan
• Smart Search
• Satellite Scan – Simultaneous Scan with 4 Satellites
• DiSEqC 1.3 Control Compatible (STAB USALS)
• Capable of Setting the Frequency for SMATV System
• Software Upgrade via RS-232C (Receiver to Receiver, PC to Receiver)
2300A:
Some of the key features of the 2300A are:
Completely redesigned on-screen user interface.
Built in PAL-NTSC conversion capabilities.
Diseqc 1.2 control including diseqc positionner control capability.
Polarizer control for mechanical polarity tuning.
S-Video output for optimal video reproduction on S-Video TV sets.
Dolby Digital (AC3) coaxial output.
Hardware power on/off switch for added security.
RS232 port for software updates.
UHF remote control port for UHF remote control kit (optional).
Loop through IF port for multiple receiver hookup.
2700A rocks but to you decide what want 2300A is discontinued product if not mistaken so warranty maybe issues.
Tony :)
he was asking about the 2500
I think the 2500 is a little better model than the 2300
I have a 1500 and the only differnce between that and the 2500 is two things
-no UHF option
-no AC-3
otherwise its the same unit...I think the 2500 can run a polarizer for C-Band or something like that :D
Icerberg i could be my mistaken but when i looked at this thread earlier it was titled Pansat 2700A Vs. 2300A?
The 2500A and 2700A are almost exactly same feature wise think 2700A is better unit.
In the future to pay more attention.
Sorry :(
Tony
Rufus
To me they are identical, except for the blind search feature. Which was ok by me when i had my 2300a.
Multiple Receivers - Motorized FTA system - Discussion
USAL plugin for satellite PCI cards
