pansat 2500 a | SatelliteGuys.US
pansat 2500 a
mark79103
3
any one know how you can get the entire program from one box to the other? i did the recommended deal it didn't work ! :confused: :D
Entire program from one box to the other on Pansat 2500A
If you have a pansat 2500A there are two ways you can get all you have on one receiver into a second receiver. First, you can save what you have in your original receiver to a bin file and using a straight through serial cable flash it into the new receiver. Second, you can do a receiver to receiver transfer, but to do so you need a Null Modem cable which is different from the straight through serial cable. :rolleyes:
Question for the professional installers
FTA inside Windows MCE 2005?
