Overscan on the 811? | SatelliteGuys.US
losvideo
13
Central Florida
I've noticed there is significant overscan on the 811 receiver. I have also noticed that I'm not the only person with this problem.
Is there any kind of fix for the overscan problem with the receivers?
I've actually connected another HD reference with a test pattern, and it's fine. It's just the signal from the 811 that is overscanned.
Any fixes available?
Thanks.
Have you tried the page up/page down buttons on your remote? They cycle through 5 different screen settings and should give you one that fits.
Yes
Yes, Even when it is set to normal, the image is overscanned.
I have run other signals into the monitor to test it out, and they all came up solid and all safe areas were showing up correctly.
This is odd, I've read that some other guys here are experiencing the same problems.
Does anyone think DISH would be kind enough to upgrade the 811 to one of the newer models thaqt are coming out?
811 local channel loss in the guide
Which 5 Satellites would you choose?
