Outlook: "sending 3 of 3" | SatelliteGuys.US
navychop
62,376
30,706
Northern VA
I use Outlook 2007 and Norton 360. Sometimes I notice when I send an email (set to do so only on command, not immediately), the bottom banner says "sending 3 of 3." But I only sent one. No additional messages appear in Sent or Deleted.
I suspect something nasty, but I do have Norton. Perhaps there is some other explanation?
It should only say 1 of 1 even if you have multiple recipients.
If Outlook is aware of 3 it should show 3 in your sent box.
Who's your e-mail provider? Can you check the account online and see if there's anything else sent?
Try uninstalling Outlook and then re-installing. I suggest downloading and using Revo Uninstaller. It's a free utility and much more thorough than the Windows uninstaller.
It may be just a software glitch, but the fact that it's not consistent makes me think you're right to be concerned.
Reporting back:
I may have figured out the problem. I previously maintained two Cox Cable email accounts as well as a Fios one. I had two email accts for myself with Cox, since Cox would not let the "main" email account be named the way I wanted. But once I set up the "main" email account, I could set up a subsidiary account named the way I liked.
So I had 3 active email accounts for several months, but only one was used for sending. I suspect that Cox had some software that "phoned home" every now and then via email, leaving no trace of itself (Cox was my previous Internet provider, now Fios). I say this because I have never seen "sending 3 of 3" since I canceled the Cox account. I think I was seeing the reporting of the message I was sending, and one each for the two Cox accounts reporting in.
Anybody know if this "reporting in" could be so?
If I ever see the "3 of 3" message again, I'll report back.
This Is Sony's $1399 Google TV-Powered Internet
Server Recommendation - Part Two
