Antenna in the attic with a metal roof would not work regardless what kind of an antenna you have!
It depends on the strength of the signals, whether you can point the antenna, and the type of roof. As stated, a metal roof will act as a shield and will likely block the signal. Asphalt shingles over plywood sheathing will lower the signal level by at least 10 dB. It will lower it further if there is snow on the roof. Bottom line is that if you are near the towers, have a 'normal' roof and everything is pretty much in the same direction, an attic antenna is OK. However, it likely will be questionable if you are 50 miles away, if there are obstructions, or if you are in an area where there is a heavy snow load.
I'm about 8 miles from all 4 local towers. Guess ill just have to get an outdoor antenna and try it out.
If you are still thinking about getting an antenna like my OTA antenna as per our PM, here are a couple of tips for you. If you do not have a pull down stairway to your attic like my house doesn't have, if possible try to make it easy for yourself to adjust the antenna. If you notice my antenna is mounted on a 3/4" piece of plywood that is not bolted down and also it is located close to an attic access hole. So if small sideway adjustments are required it is easier just to stick your head up in the attic and move the plywood without having to go up into the attic. But of course this all depends on where you mount your antenna in the attic. Also, you never know if an antenna is going to work or not, there are lotsa variables as you can see in this thread. Check the return policy before you purchase in case you have to return it.
I'm curious as to the brand & model of your antenna. If it works well it seems to be a fairly compact design.
Sent from my Droid RAZR MAXX using Tapatalk2
You never mentioned what type of roof you actually had...
Another place you can put it is in a closet. If you are 8 miles from the towers you should work as mentioned with rabbit ears, but you might not want to have them poking up behind the set.
If you can keep your antenna indoors it will be much more reliable in the long run.
At 15 miles rabbit ears would probably work in your attic.My antenna is under asphalt roofing and works just fine. Been there 13 years. Looks brand new. I get great signals on all channels. No amp needed. Transmitter is about 15 miles away. I have an antenna for high gain on VHF hi and UHF at around 50-70 miles. So I figured the extra gain under the roof would work out just fine. In every day use, it does.
Limited time offer
