OTH ant setup | SatelliteGuys.US
OTH ant setup
HP Pavilion 6580
3
Has anyone been lucky enough to get an oth like a Turk to work with a dish setup? It worked great with Direct. I have a 622, will it mess up the signal if I try to use it? Has anyone been able to get HD with one?
I believe he meant OTA (Over The Air). Stay away from the Terk. You would do much better with a Winegard or Channelmaster. You can diplex the signal, but it's always best to run a seperate line. If you get a signal, the quality is better than what you pick up on satellite.
DishHD Package channels
Reception Report HD Mpeg v 6000
