OTA without Voom Box - Please somebody help! | SatelliteGuys.US
Not open for further replies.
smodak
162
I am trying to use OTA in my HTPC without the voom box using the voom Sensar II antenna. I have a diplexer install. I cannot get up the roof to discconnect the diplexer or the dish so I bought a Radioshack diplexer to be used at the receiver end (call it X). I took off the moto diplexer which came with voom at the receiver end. Whan I connect the 'satellite out' of X to the voom box 'satellite in' and the 'antenna out' of X to the voom HTPC , everything works great. But the idea is to get rid of the voom box altogether and so I bought a Winegard 9370 power supply and disconnected the 'satellite out' of X from the voom box and connected to the power supply and it does not work? What am I doing wrong? Is the power supply bad? It does light up the LED. Also I tried to plug the antenna/sat coax directly into the PS and X to the "antenna out" of the PS. I also tried X completely out of the picture.
If I want to keep the dish and diplexer on roof intact, what would be the best way to connect a power supply at the receiver end and the antenna to the HTPC and get rid of the voom box altogether? Please help...
http://www.winegard.com/offair/powersupplies.htm
Since this is a duplicate post and we are already discussing this in another thread, I am going to delete this one. Ok?
Sure!
Using a Diplexer With Voom Cabling
Question: Will Voom work for OTA after 5/1
