OTA with DPP44? | SatelliteGuys.US
OTA with DPP44?
Fooshnik
Is it possible to diplex an OTA antenna into (or out of) the DPP44? All the diagrams on Dish's site (like this one) show this done with a Super Home Node, none show a DPP44. I've tried putting the antenna and a sat line into a diplexer and the into one of the DPP44 inputs and I've tried it with the sat out and OTA into diplexer going to the TV. In both cases the the Dish satellite works but the antenna does not. I'm using 110, 119 and 61.5. Did DISH HD start interfering with an OTA antenna? I thought it didn't. Ideas pls? I don't want to have to stand in the corner holding the antenna during super bowl.
Dishnet switches do not pass OTA you need to diplex it into each individual receiver line that needs OTA.
If you are using one of the switch input wires to bring OTA from the roof to the switch location, then you can use diplexers to separate the two signals before the switch, and then diplex the OTA signals back onto the individual receiver lines.
Dish switches do not have splitters in them to split OTA from an input to all outputs. I believe they also have bandstop filters built in to them.
Dish 322 & OTA HD
Does anybody have IPTV in Texas ?
