ota signal | SatelliteGuys.US
ota signal
No, this is a hardware limitation on the receiver (OTA is only provided to TV1, except with the OTA module that some receivers use). You may be able to run a cable straight from your OTA to your TV2 if the TV can pick up the digital OTA channels.
correct me if i'm wrong cause i don't have a 622 but do have a 722, but if you were to put your reciever into single mode you would have OTA on both. you would lose independent viewing from the rooms though, both rooms have to watch the same thing. just a suggestion.
DISH Network files fcc application to transfer terrestar licenses
Dish Movers
