OTA Reception Problems | SatelliteGuys.US
polksda
80
Urbana, IL
I have the line from my rooftop antenna split, with lines then going to the Voom receiver and my Dish 811 receiver. The Dish 811 picks up all my OTA channels just fine, whereas the Voom receiver is not picking up any.
Is the OTA tuner in the Voom box of lower quality than that of the 811?
If you are not getting any, most likely it is not connected properly. Check your connections. Are you sure you are using the correct input?
vcr recording hookup help
New Install + Pin Problems
