OTA Question | SatelliteGuys.US
OTA Question
lsh1885
SatelliteGuys Guru
133
Orlando, Florida
Yesterday I hooked up an outside antenna to my 811 so I could get digital locals. After scanning, some of the channels have incomplete info on the guide. Most of them just say under program name "Digital Locals" and some just list the digital number with no station call letters "41-1". Is there a way to change the channel names manually so other people who are watching will know what channels they are watching.
811
Yes, there is a way to add "ABC", etc. to the channels but I don't remember how. It describes how to in the 811's manual.
Instead of allowing the Receiver to Scan for channels,
if you
ADD DTV of digital station or something like that then it will ask for the UHF station number, once it locks, you can save it and assign a 4 character name to it such as KXXX or whatever
menu 6-1-5.. ADD DTV
Since my original post all but one channel are now being displayed properly by the guide. I'll try to add the other one using the method you describe. Thanks!
newbie help
921 and Bell
