OTA availability question | SatelliteGuys.US
OdiOdin
110
I went to www.iwantmyhdtv.com. However, it would appear that if they were to get this bill passed I wouldn't be helped because HDTV is officially available in my area. I was told this was an impossibility sense I am 80+ miles from the broadcast sites.
is this a case of just needing a better antenna then the hicks around here know about?
I don't think so, 80 miles out sounds like SOL territory.. but i'm not an expert :smug
Go to atechfabrication.com and click on antennas. The dual setup using Blakes has a long range. A lot depends on your local terrain. I know a guy that gets San Francisco from his house in Georgetown [ in the Sierras above Auburn ] with no problem. That's well over 100 miles. Go to antennaweb.org and put in your address. If you get purple for your digital channels then thats the setup you need.
dpp+ 44 sw question...
Are there any satisfied DISH customers
