OpenBox S9 HD 480I/mpeg1 question | SatelliteGuys.US
perkunas
36
Ontario Canada
This receiver is sluggish to turn on and off, I can live with it though.
What gets me, is that on galaxy 19, all I get is 480i/mpeg1 is that it all I get?.
These channels should be mepeg2 minimum, running 1080i (no p option) but that doesn't mean much, its just up converting.
Prob says mpeg1 but maybe its mpeg2 IDK seems like a rip didn't 480i/mpeg1 go out with the dinosaurs.
There are a few MPEG4, H.264 channels on G19, but there are no video MPEG1. Occasionally there is a 720p or 1080i occasional use signal on G19, but all 24/7 channels will show 480i and a few 576i.
Maybe the audio services are displaying MPEG1 on the information screen? The ALI chipsets did not display service information very well. Most of us had to work outside of the SDK to provide useful service information.
1080 (i or p) is the output resolution setting for the HDMI connection for your monitor.
Thanks it sounds like its correct then, 480i is what ill get, from what I understand mpeg1/2 two are similar as far as the chip-set is concerned, its Probably running mpeg2 anyway.
OTHER X2 Premium > Vbox & USALS motor!
GEOSATpro 1200
