"only one satellite is connected" | SatelliteGuys.US
xtreme816
I have Dish500 with a 301 receiver and have been having problems with it for about 3 weeks now. It is now telling me "only one satellite is connected" on the install summary page. Satellite 110 is the only one connected and I only get my local channels and a few others that I never watch. So I was wondering if there is anything I could do to try and reconnect satellite 119. any suggestions would be great.
You need to post a LOT more information. Like full details of your Check Switch screen, and also go outside and look at the dish and LNB and tell us everything about it that you can.
In the meantime, try disconnecting the satellite feed, pull the plug on the receiver, and start again with a Check Switch - you might get lucky.
Unable to acquire signal...
retrofit oversize reflectors for 300 or 500?
