One receiver for multiple rooms? | SatelliteGuys.US
hixon
2
Is it possible to have one receiver provide channels to multiple rooms? I realize they would all have to have the same channel at the same time. Also, is it possible to have multiple remotes in separate rooms control the same receiver, even if the receiver is in a different room?
Thanks.
Receiver Distribution
Yes, you can to both questions. You can use the Channel 3/4 output into a home distribution system using a splitter for a couple TVs or a multiple output distribution amplifier or amplifier/splitter combination for longer runs or mor TVs. Modulating the receiver audio/video output with the above distribution methods allows more receivers and also DVD/VCR distribution. A wireless adapter is needed to use remotes in other areas remotely.
Problem Installing 5 LNB Antenna
CD USA: Live From Las Vegas New Years Eve
