One channel , no signal | SatelliteGuys.US
richard4019
2
Hi all!
I'm not receiving channel 206 . All other channels are OK. All other ESPN channels are OK.
Ideas please.
Richard
SD signal doesn't come in. The banner appears, screen blanks and then Searching for satellite signal message appears and then the systems after aboit a minute recycles through the the steps again. Have reset the receiver also . Direct TV customer service has not been able to help either. Anyone have any ideas?
Richard4019
Could be a bad fitting. I have had that before -- some channels wouldn't come in although there was excellent signal strength. Replaced a couple of hex-crimp fittings and the missing channels appeared. A staple too tight could also do that.
Install this Monday-HR21 or HR20?
Triple LNB for 4 Receivers (combine signals?)
