Omnidirection HDTV Antenna - VHF/UHF | SatelliteGuys.US
Jake_E
13
Fayetteville, NC
Omnidirectional HDTV Antenna - VHF/UHF
I'm looking into getting an outdoor omnidirectional HDTV antenna to go along with a coming FTA installation, with the signal being split to 4 different televisions.
Being in Fayetteville, NC, all of our stations are pretty well dispersed, Raleigh/Durham, Greensboro, Wilmington, etc. The big stations that we want to get are all within 30-45 miles.
I've basically narrowed it down to the Channel Master CM 3000 or the Winegard 2000 (there's also a 2002 at the same retailer, but I don't know what the difference is). They look pretty similar, so I was wondering if anyone has any experience with either or both, compare/contrast, etc.
Thanks.
You are going to need a much better ant. for what you want to do, the stations are more that 30-45 miles.
You will need a rotor and and an ant with more gain that the 2 you are looking at
Our Terk HDTVa is working great indoors, maybe I'll just stick with that...
We don't even move it, we've found a "sweet spot" so to speak that gets all of the channels we want without a single problem, even though they're spread out over almost 360 degrees.
I may give the omni a shot anyway, mounted near the ridgeline of our roof.
DISH OTA Signal dropout solution
DTV and HDTV programming details
