Looks kinda like a Dove bar?Should have put L shaped
My recommendation: DON'T REPLACE IT! if it works.thats it. what would you recommend for a replacement?
You should get a 2x4/3x4 multiswitch instead to recombine the Horizontal and Vertical coax outputs together for ease of use with FTA receivers.
That LNB may give slightly lower quality, but you won't have much fuss from it, unlike other cheaper LNBF's
since I'm looking at making this stationary for now and locking in on G 18 would this work with only one line connected if it was hooked to the correct one? If so would that be Hor. or Ver??
since there isnt much on H on G18 you would just hook up the line from the V side of the LNB to the reciever
Limited time offer
